Whatever type of DIN Rail Meter you choose, be wary of the digital type, my company now fits Landis and Gyr E110 (non- DIN Type)instead of the previously used ABB OD1365. It's not really a DIN issue but the ABB meter also showed polarity by means of clockwise rotation arrows on the display (which meant correct polarity). At night time when the panels stopped producing, this meter would show an error code and the arrows would rotate backwards, probably due to the invertor taking a small amount of supply from the AC supply, even when it is waiting for DC supply. This then led to customers complaining when there wasn't actually an 'error', just a meter that gave too much information. After all, most people who have microgeneration systems newly fitted will often stand and stare at their meter as this is the only proof of a healthy install they have that their knowledge allows them to understand. This is another factor worth considering because if you're run off your feet doing these jobs, you may not have time to then go on 2nd visits to exchange meters for simplified versions.
