mikeyranks
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus consumer unit which is fully loaded with RCBO's.
I got a guy round for a quote and he said if it won't fit on the DIN rail it would be fine to leave it loose inside the unit. I'd prefer a larger enclosure than have a secondary consumer unit box next to it as I want to keep the overall wall space taken up by the CU, Meter and incoming supply as small possible as it sits above the front door.
Is leaving it loose acceptable? Are there any regulations that say this is not ok?
