Spoke to a chap at the IEE the other day about something similar to this - was putting a light in the cupboard under the stairs beside the CU and just putting it in beside the existing downstairs lighting on the same 6A mcb. I had assumed it would just be a meiwc but he said it would count as a new circuit! So what would you give for a spur at the origin on a ring or radial, minor works or eic??
Wouldn't he fall foul of regulation 314.4 regarding each final circuit shall be connected to a seperate way in a distribution board. As an EIC is for a new circuit. Did he square that one off.
He wasn't being all technical and say that a CU is not classed as a distribution board as such was he?
That's rubbish, define 'a circuit '
By that logic, you'd show emergency lighting doubled up at the mcb for the primary lighting as a separate circuit with separate certification!
