sparkywoman
Can a Sunnyboy SB3800 inverter disconnect on a TT system fast enough to prevent injury through shock?
The installation has an RCD fitted and the inverter is connected to a 16 amp MCB.
With the inverter having simple separation, does this negate the need for an RCD to protect the cable between the inverter and the consumer unit?
