Discrimination headache!!! | on ElectriciansForums
Discuss Discrimination headache!!! in the Commercial Electrical Advice area at ElectriciansForums.net
Norfolk
Thought I'd try out this ElectricalOM software for a new installation I'm designing. However come up with abit of an issue with the discrimination on 2 of the devices. Single phase sub feed from DB2 (60898 type c 63A 10kA) to DB3, Final circuit from DB3 (61009 30mA 32A type c 10kA RCBO)
Time v Current curve for the devices shows no discrimination for over current protection.
Any ideas or advice?
Hi, that's a lot of tiers, try reducing, also you need to ensure your fault current analysis is correct.
Reply to Discrimination headache!!! in the Commercial Electrical Advice area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
