Then you are my savior??
Well I removed the draining pump then I cleaned it and I put it back in. The problem happened the first time I removed the pump. Then I removed it 2 other times to see if I had done something wrong. Not taken appart, I just remove the bottom shell to access the pump. The DW doesn't care about opened doors. Normally when the door is open it's when you can do the setting. The LEDs are on and then when you close it the program starts.
Thanks for your help!
[automerge]1586459589[/automerge]
Well I did call someone, many companies actually lol. Nobody wants to come due to the Covid
. Maybe the fuse can be a lead but I cannot find it. I'm just wondering whether the button would be beeping if the fuse was burnt.
