Discuss DIY Earthing !! in the UK Electrical Forum area at ElectriciansForums.net
see it literally countless times like that, crap but it works, if the reading is okay then great, what would you do otherwise to that out of interest? apart from cut the plastic away from the cable LOL
I wasn't having a go M8, just wondering what else you could possibly do, as you say it's not your problem anyhow.I dont intend doing anything at all. Thats up to the electrician she is employing to carry out work there.
I merly examined the system to ensure it was SAFE...
not necessarily..Crikey
Yes Glenn I'm aware of that although I might be inclined to dispute the coding, the comment was more in surprise at the Ze than the clamp. I've seen boatloads like this, and worse.not necessarily..
seen loads of these...
look, it aint rite ....we all know it need a constant pressure spring n all that lot...
but as long as Ze is rite....then it`s a 3...no more...no less...
excactly...as eng. says. and what makes you think that the cable is undersized? have you used the adiabatic?
Reply to DIY Earthing !! in the UK Electrical Forum area at ElectriciansForums.net
