DIY LED strip stairs | Page 2 | on ElectriciansForums
Discuss DIY LED strip stairs in the Lighting Forum area at ElectriciansForums.net
Good news everyone, the setup with the two PIR sensors and the LED strips connected in parallel worked. The only small thing that is not ideal is the fact that when the second sensor is triggered after the first one already turned the lights on, the LEDs closer to the second sensor become a bit brighter. I imagine that as the voltage drops a bit from the first LED to the last, triggering the second sensor while the lights are already on reverses the direction of the power (the last LED gets power first). It's not a huge difference and I can definitely live with this setup. Thanks to everyone for your guidance.
Hi designabc
if you were to use thicker red & black power wires up to the top sensor, or maybe try another pair of wires in parallel, you might lessen the effect you mention.
Pleased to hear it's all working.
Hi designabc
Thanks for the tip! It's a very slight difference and I've already done so much with this setup as it's not worth removing the old wire and doing it again, but I'll definitely know for my next PIR + LED project.
Reply to DIY LED strip stairs in the Lighting Forum area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
Thank you so much for your help I appreciate it alot. I learnt alot and saved alot of money in the progress kudos. Best wishes to you too.:bowing:
