-DIY- Powering a 3 volt LED from a 4.5V supply | Page 4 | on ElectriciansForums
Discuss -DIY- Powering a 3 volt LED from a 4.5V supply in the Lighting Forum area at ElectriciansForums.net
I do not need recompense because I like helping out and these problems provide me with interest and mental stimulation but if you feel inclined perhaps make a £5 donation to the NSPCC towards their very good work. :)
NSPCC - https://www.nspcc.org.uk/
Yep I will do that.
So would you say I'm fine to use the soap reactor on any LED light up features?
Yes - you are fine to use any of the eight 4.5V 30mA outputs.
Each output is the equivalent of a electro-chemical battery as used in a figurine to power the led lights. The internal resistance Ri of each output is acting as the 'compensator' you mentioned so there is no need for an external resistor to do that - a battery also has an internal resistance.
For the higher amperage outputs - if you want to use those to power LEDs we'd need to talk again because they will have a lower internal resistance which is most probably not suited to powering an LED directly without introducing an external resistor - which we'd have to determine - not difficult.
Brilliant, thank you for all your help :)
Reply to -DIY- Powering a 3 volt LED from a 4.5V supply in the Lighting Forum area at ElectriciansForums.net
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
