DIY Very Big Bang | on ElectriciansForums
Discuss DIY Very Big Bang in the UK Electrical Forum area at ElectriciansForums.net
Ricard
London
I am not a professional electrician and am posting this partly for your general amusement and partly to get some background advice.
My son who has recently moved into a rented flat in Nottingham having got his first job there, decided to put up some coat hooks. He seems to have taken insufficient notice of the fact that the consumer unit is above where he was drilling. Apparently there was a very big bang and the hole shown in the picture appeared without any further exploration on his part.
He phoned me for advice and sent me the pictures, mentioning that none of the fuses seemed to have blown and everything is still working. I explained that the reason no breakers had tripped was that these are the main cables coming into his consumer unit and therefore before his breakers. I am a bit surprised that the company fuse didn't blow, but I guess it must have been a very short bang.
My advice was call your landlord's agent, you need an electrician because there is no way you should attempt to do anything with this.
The consumer unit is near the ceiling on the opposite side of the wall to the meter cupboard.
My questions are first will there be any way to fix this other than digging out the cables and replacing them from the meter to the consumer unit.
Secondly to ward against the agent inflating the cost, what sort of ball park cost should it be.
Finally, is it appropriate for the main cables to be buried in the wall without any protection (from idiots).
  • [ElectriciansForums.net] DIY Very Big Bang
Those tails will need to be dug out and replaced. They will also need either RCD protection at the meter side or mechanical protection to prevent this from happening again.
Ideally the tails should be routed to negate the need for an RCD. It's going to cost him a few quid...
Send him this link: https://lmgtfy.com/?q=safe+zones+for+cables
There should be RCD protection on those tails as they're buried <50mm without mechanical protection.
The only way unfortunately would be to dig it out to inspect further and potentially replace...
Looking at it the left hand side earth cable (looks like a 10mm from picture) could be connected to the gas or water pipes, arcing could potentially bring the pipes up to 240v - would advise to get someone out to at least have a closer look.
You should not permit anyone to install an RCD on the supply side of the tails, it is likely your son will be plagued by nuisance tripping with total loss of power each time. This is would be a departure from Bs7671.The best option is to run new tails and earthing conductors in surface trunking which will remove the need for RCD protection on the supply side.
How long ago would regs requiring RCD or physical protection have come into force.
Hopefully some one will come along and confirm or correct this, but I think it was the 2013 reg changes or was it the 2011 to have cables buried 50 mm deep or have additional protection.
Sorry I was absolutely no help whatsoever ever there.
I would get someone out to replace the tails, however I am disappointed to see no capping over the cables to protect them from the plaster.
Be nice to see the damage in relation to the consumer unit.
Are they directly below? Is there any mechanical protection.
If not id be trying my hand at claiming its not correctly installed and look to dodge the bill.
Oh and pass on my congratulations, damn fine shot that.
2mm to the right and you would have a live coat hook installed for the mother in law!!!
Pretty insignificant compared to the fact that there are live tails directly under the plaster with no protection though!
Hmmm, considering my son is an engineering graduate, it does look rather like he was trying for a Darwin Award.
It looks clear to me there is no mechanical protection.
The building is probably 1960s or 70s I don't know when the electrical instalation dates from. But if there should have been mechanical protection then that might help reduce his bill.
Not much wiggle room there to ne honest, other than mechanical protection, the cables are where you'd expect them to be.
Might be worth confiscating his DIY toys until he can prove hes not suicidal
Reply to DIY Very Big Bang in the UK Electrical Forum area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
