T
tottenham steve
Having discussed the event codes with SMA, they are saying that the disconnections are caused by high grid impedence caused by an initial high grid voltage
This thread titled "DNO turning off systemsDno turning off systems" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
Sorry, I dont know, but its quite rural , i would guess at less than 20Sorry to ask again, but how many properties does the DNO supply from the transformer?
I think you're in trouble then, and the DNO has obviously made a mistake in giving you permission to connect 10kW on to that line.If I stick to those limits the system will disconnect, How is the system supposed to work?
We fitted a 10kw system a few months ago, G59 approval was granted prior to installation and all was carried out correctly.
unfortunatly there is high voltage in the area so the inverters were tripping at peak generation. We have recalibrated the inverters but still have a problem.
so we have asked the DNO to look at there transformer and after investigation they have concluded that our system is causing the transformer voltage to rise above there upper tolerance and ordered the system to be shut down, leaving me £30,000 out of pocket. Has any one else had the same experience?
I didn't think you could use VO's in that way - to feed power back to the grid through them.i would be looking at voltage optimisation to see if that would help the over voltage,gonna be alot cheaper
Okay, what about if a system is installed and the grid voltage seems fine. And then the neighbours get systems installed. This would presumably have an effect on the grid voltage. Could the DNO really ask someone to turn their PV system off? Whose responsibility would this be?
Reply to the thread, titled "DNO turning off systemsDno turning off systems" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
