Do crimped connections in a choc box in an inaccesssible location comply with regulations? | on ElectriciansForums
Discuss Do crimped connections in a choc box in an inaccesssible location comply with regulations? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
reading
The relevant regulations are I think as follows:
BS 7671 513.1: cable joints must be accessible except where allowed by 526.3
which is covered by ...
BS 7671 526.3 (iv) joints made by welding, soldering, brazing or compression (which covers crimped connections)
So far so good. But:
526.5 (iii) Every termination and joint shall be in an enclosure partially formed or completed with non-combustible material.
This I think does not cover a choc box which is as far as I can make out is made of polyproplyne which is combustible.
Am I missing something?
I know you will all say I should use Wago connectors in a Wago box which is obviously correct, but I want to know how I should treat existing inaccessible crimped connections in a choc box in an inspection.
later ...
I found the specification for a Greenbrook CHOC30A which says it conforms To BS EN60670-22, which is the standard for "Boxes and enclosures for electrical accessories for household and similar fixed electrical installations". So these choc boxes comply with BS 7671 526.5 (i) "A suitable accessory complying with the appropriate standard", and are therefore actually OK.
Reply to Do crimped connections in a choc box in an inaccesssible location comply with regulations? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I was hoping so. What rules apply here?
5K
Two ways for me either Wago's or Hager Face Plates which have a Neutral connection built in to switch plate.
C
J
TysSome infopical questions asked by installers Should WAGO connectors be used in an enclosure? In order to comply with the requirements of the...
24K
nickblake
N
E
Welcome @Geraldine you may be better off starting a new thread with more detail as Edd is no longer a forum member.
80K
C
You have a valid point Tony but had this member not posted in this thread then I probably wouldn't have had the pleasure of reading it. Very...
33K
1shortcircuit
