Dodgy LayZSpa | Page 2 | on ElectriciansForums
Discuss Dodgy LayZSpa in the UK Electrical Forum area at ElectriciansForums.net
Steviecuk
Essex
Hi all.
I have had my LayZSpa a few years now and it was a few years old when I bought it. A few months ago I felt a shock when I was standing on the (wet) decking and then touched the water. I got the MM out and it read 50v to both the decking and of course into the ground/earth.
I then took the lid off and found that one of the two heaters (ceramic strip heaters attached to an aluminium tube of which the water passes through) was shorting against the tube. I read 77v to the outside of the housing. This obviously then in turn passed into the water and caused the shock.
On inspection of the design I found that there was no earth wire what so ever going to anything, not even the metal housed components. In fact the main power plug was only a two core lead!!!! There is no in-built RSD and only a thermal cut out which obviously won’t stop my problem.
I disconnected the faulty heater and screwed a ground wire to the metal housing and run this outside the unit and into a temporary ground rod in case the same things happens again.
Looking at the new design of their hot tubs, they are now incorporating an earth loop connecting to the internal components and have now fitted a sensitive in-line RCD.
question time.
1. Was their first attempt at this design safe? Or should I say safe enough to merit a CE mark?
2. Who can I complain to in regards to the above if you think it’s not safe? I’ve complained to them but they’re batting it off.
I am assuming that they have learnt from their mistake previously hence the new safety measures, but that still leaves me and a number of others out there with a ticking time bomb of electrocution.
Your thoughts please.
Thanks. Steve
[ElectriciansForums.net] Dodgy LayZSpa
Is there an earth stud at the bottom/underneath of that unit?
No not on my one (same as the top picture) No earthings what so ever. That’s why I think that their first models were so dangerous, there is absolutely nowhere for electricity (Albeit if shorted to the heater block) to go other than directly into the water
Hmmmm. Your thread, made me think of getting one of these, but the company - Bestway - hasn't got very good reviews for customer services, and seems some people have been unlucky with failures. So I'm not so sure you'll get any good advice from them.
Seem to recall @telectrix has one, he might be able to advise, with his experience.
Looks like you’ve got an older model, I’ve have one of these for around 4 year’s now and The internals look the same as the bottom picture. I know this as I’ve had it stripped down to clean out the heating element and pump because it gets a build up of calcium in there. I can also confirm that there is an inline RCD on the flex of the newer models.
I don’t think you’ll get much joy from customer services at best away as they only have a 2 year warranty. However I found them useful when I contacted them and they sent me replacement transformers for the lights that failed twice within the warranty period.
If that was mine I’d skip it and buy a new pump unit for the spa, I wouldn’t be risking getting in there at all, it’s dangerous.
Off topic, how reliable are they, customer service etc?
To be fair, mines done me ok over the time I’ve had it and lasted well. The heating elements do tend to get a build up of calcium over time (which is to be expected as I’ve had it 4 years), this was causing the water inlet to block and shut the pump down due to the back pressure. But since cleaning the element and drilling slightly bigger holes on the inlet grill I’ve had no other problems with it.
The only occasions I’ve dealt with customer services was through email (both times), I found they were a little slow to respond but sorted the problem on both occasions after the lighting transformer failed.
All in all, I’m happy with mine as it’s had plenty of use and kept on going.
I want to install a proper one at some point but while this keeps going I can’t justify it.
Not having an earth does not automatically make it dangerous there are reasons the manufacturer might not want it to have an earth and instead make it class 2 (double insulated) A big reason could be for it being plugged into PME / TNCS earthing arrangement (youtube john ward PEN failure if want to understand more) also with these units being outside most of the time a metal cased item with exspsoed conductive parts is subject to corrosion
The instructions clearly state must be plugged into an RCD protected socket (for extra protection), most houses from 16th edition have the socket ring final circuits RCD protected, and if not the user can buy plug in inline RCDs
A double insulated device is not dangerous in good condition, if you take a double insulated electric drill smash the case so badly you can touch live terminals inside and presenting a shock risk, this does not mean the product was originally dangerous. (Although maybe the Layzspa needed to have better build quality)
Banging in and earth rod as you say (without testing the rod for its effectiveness) is not a solution
Great video and I do get that now. However it appears to be a vicious circle. On the other side is that if there is no break in the neutral before the N/E split, and the metal housing of the heating element shorts live, someone dies. I would have thought there is much more chance of that happening than the N/E breaking no? And given that the company have started making it that way suggests the noticed this and put it right??
Aren't modern houses grounded using a dedicated rod now? Mine is 11 years old.
It is protected via a 30mA RCD.
I get that, but I haven't smashed it open, the ceramic heater has naturally broken down and shorted against the metal casing of the heater making the entire spa go live. Wouldn't it of been the proper way to ensure that this is protected against should it happen? This is the point I'm trying to get at.
I'm not using it, I only did that so that it was relatively safe whilst I was conducting tests. I'm not saying its a permeant and adequate fix.
[automerge]1596895823[/automerge]
Thats excellent thank you for confirming this.
I will be skipping it but my point is I think they should be liable for making a product that can easily be made to make the water live without any apparent safety features. Well, I mean it happened didn't it! I was electrocuted... lucky it wasn't 230v or I'd likely be dead!
[automerge]1596896058[/automerge]
I have just read this:
Class II[edit]
Class II symbol
A Class II or double insulated electrical appliance is one which has been designed in such a way that it does not require a safety connection to electrical earth (ground).
The basic requirement is that no single failure can result in dangerous voltage becoming exposed so that it might cause an electric shock and that this is achieved without relying on an earthed metal casing. This is usually achieved at least in part by having at least two layers of insulating material between live parts and the user, or by using reinforced insulation.
Assuming that that is all correct, There is only the one insulated case that is between the metal housing of the heater and the outside world. However there is NO insulated casing in between the metal/ceramic heating element and the water that runs straight through it and so no insulation from making the water live.
[automerge]1596896495[/automerge]
I have just checked the label and it does in fact have the Class II label. However my question above still stands, how can this be two pieces of insulated material between the end user and the live live parts should it fail? Or doesn't it matter if it fails and goes live? The fact that the water has gone live AND that they have completely redesigned their pumps for safety surely suggests their initial design was floored no?
Regardless of manufacturing problems lashing an earth in won’t make it safe. My advice is skip it.
If you’re that concerned commission an engineering report then contact trading standards with their findings.
As an engineer that’s reported a few products to trading standards they’ve never shown any interest in any of the dangerous products I’ve reported.
[/QUOTE]
[/QUOTE]
If it has a Class label II, that would explain the supply lead. As regards the breakdown, that might be just the life span of the apparatus. I can't see any legs on trying to get any redress on this failure, it being a second hand product.
I would just scrap it, and buy a new one from a reputable source. However, I see the main UK retailer is out of stock on all models. Must be popular?
Yes everyone is
[/QUOTE]
[/QUOTE]
yeah everyone is buying one because of the lockdown. Thankfully they’ll be the protected versions.
I get what you say about the life of the product, but surely one can’t be expected and certainly just accept that they will be electrocuted just because the product comes to the end of its lifespan. My last car didn’t just explode with me in it because it was 15 years old.
I kinda expected different comments to be honest. Maybe I’m just naive but not being a spark, I think it's unbelievable that a product can be sold that can so easily end up killing someone from a simple short.
Yes everyone is
[/QUOTE]
[/QUOTE]
I like the 15 year old car quote :- D
But yes probably quite a major design flaw, maybe they have now changed the design but i doubt they are going to scream and shout about there old ones being unsafe!
Heating elements in water always increase the risk of a shock and have a tendency to break down as they get old (only last week i replacend my immersion heater), maybe a better way for them to have done it would be too heat different water / a coolant and then using an electrically insulated heat exchanger transfer the heat from the coolant water to the hot tub water, but then maybe this costs more to make, etc etc
This thread reminds me of Dolphin showers which had bare heating elements and pressure switches immersed directly in the water they were heating, inside a clear plastic housing. I think it would be quite possible to make a fairly safe class II spa heater/pump.
Reply to Dodgy LayZSpa in the UK Electrical Forum area at ElectriciansForums.net
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
This is a baffling fault I've been fighting with for a couple of weeks now, so I wondered if another set of eyes will help. I installed an EV...
