Dodgy trade pictures for your amusement! - 1 Million Views! | Page 119 | on ElectriciansForums
Darkwood
Dodgy Dave has been doing the rounds again. These are all in the same place. Where do I begin :rolleyes: can fit your finger through every one of the holes on the top surface no protection for the cables entering the bottom or the side dodgy set up where that 2.5 t&e’s nuetral feeds something else in the CU god knows why old heating box tails enter two different holes unused holes in the old heating box that you can stick your finger in random unprotected joint down below CU.
Oh and the MCBs etc haven’t been fitted correctly so there is half a device’s width at both ends of the CU with no blanks aaaand a lovely pokey up bit of uncapped busbar just waiting to zap you if you try and reset your tripped lights in the dark and put your finger through the hole. What a mess...
Almost forgot that’s a joint taped up on the earth there just after the Henley block
Flex from a socket inside the garage, no fused spur protection and no earth connected in the flex, to this switch outside the garage feeding an outside light. The switch is mounted on a 1G KO box with no grommets and open holes. The neutrals were twisted together and wrapped in sellotape.
Sound job then?
Merry Xmas to all :D
