Darkwood
Will the NICEIC be bothered if I reported it & asked them to come & inspect?
Doubt it - anecdotally they don't seem to be bothered unless it's so obviously dangerous that they can't find a reason to ignore it. Can you argue that segregation has been lost between your ELV cabling and their mains.
... they have strung their cables from the rafters, using offcuts of T&E with a screw through it for cable supports.
Plastic coated metal hangers then :-)
Plastic coated metal hangers then :)
seen the old off cuts cable hangers loads of times usually just nailed to the joist...
it’s not a bad way to bunch cables and to hold them up in place.
i have even done it myself when I was out of all round band.
I was instantly inclined to the same view as Julie...however, paper like that, if properly hung, could designate the prescribed zones...you'd just have to get the stripes in the right places...
It’s fairly easy to burn pvc cable if you pull another cable against it Too hard...
I wouldnt be happy with the burned Cable...but unfortunately It’s fairly typical to see This sort of thing
Anyone who treats coax cable like that would not be fitting an aerial for me. I hate to think what his terminations are like.
8K
Darkwood,
vjsmarwick,
