Dodgy trade pictures for your amusement! - 1 Million Views! | Page 270 | on ElectriciansForums
Darkwood
Here's an old DNO cast iron cutout/splitter box serving a few Housing Association houses,[from the late'50s/early 60s?] the cable must be close to 50mm diameter. I was working in one of these places that's been privately bought doing a CU change. Not putting that picture in the 'dodgy' thread though. ?
  • [ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
I’m not sure if this was the electrical contractors or the internal bodge squad (aka the projects team), but this was fitted in the last few months as part of a new working area to feed an external container with a double socket, and a few lights in SY. There’s a heater element in an IBC that seems to be supplied from somewhere else too.
Brand new Contactum enclosure with RCD main switch. Buying Contactum MCB’s at the same time was clearly much more difficult than butchering the enclosure to fit the Crabtree.
I’ve not fully traced it out but I think the D16 feeds an RCD double socket in the container, because whoever installed it hasn’t heard of selectivity either!
EDIT: I forgot to add the SWA supply from the other side of the plant is glanded onto a rotary isolator that’s then glanded to the Contactum enclosure, presumably with galv conduit but it’s basically flush so probably not given the quality on display. I’ve not opened anything up, mostly out of fear that things can only get worse underneath the veneer of crap.
nibbled out the cover of board with side cutters , very creative solution
side cutters?
Looks like he used his teeth!
(I got really confused there. You must have been editing your post as I pressed reply... thinking “that’s not what it says???”)
On the same note, brand new board, couldn’t be bothered to get the correct fitting MCB.
Landlord said he had an EICR done a couple years ago and this wasn’t picked up then!
FFS it is not like they are hard to get or obsolete ones, I would imagine a 5 min trip to local Screwfix!
Also looks like the RCD's N fixing has been bent as screw appears no longer lined up to the access hole.
do you mean the L? it's the bent busbar that's causing that.
