View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
I know. But my experience round here is that if it says 100A it generally is. They usually stick a label on to say 80A.
It’s possible but I can’t confirm without the DNO pulling it for me.
Is it sealed?
If not, says it all.
If so, they've sealed the meter with a 16mm T+E outgoer......is that right?
Joke all round.
They have already given them a ‘don’t call us we‘ll call you!’ They had their concerns hence asking me to give a second opinion.
I guess the last inspection was by ‘Bodgeit & Scarper’ ?
Out of interest, are Bodgeit & Scarper a member of any of the scams ? If so then 2 things come to mind :
1) It's proof (not that any more was needed) that scam membership is no guarantee of even safe work - let alone good and standards compliant work.
2) It needs reporting and see what happens. My w.a.g. on that would be "s.f.a." ?
So whoever fitted the meter is the one who connected the source end of the 16mm2 T&E?? Word fail me!
Incidentally, I used to do the odd new build for a local building firm, and when they paid me, the cheques were genuinely in the name of Bodgeit & Scarper.
It would appear so. Although I’m not overly convinced this has been done by the DNO.
Then again this is the state of the service cables. ??‍♂️
Service cable looks like the work of whoever fitted the uPVC soffit and barge boards.
If the meter has the correct seal on it and it hasn't been tampered with, then it must have been the meter installer, unless the T&E is wedged in with matchsticks.
There is an entire housing estate near me (I think built around 1985/1990 ish) wired in exactly the same way as the above picture, 10mm twin and earth connected to the meter which then snakes up through the cavity to the consumer unit. I have worked on dozens of these houses and all are wired in twin n earth from the meter to the board. So can only assume this was the original design and connected by the DNO like this
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
