View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Speaking of prescribed zones.
Property shows on TV. Awful.
Last nights was “Worst House On The Street” where a developer buys the worst house on the street and does it up a bit….
“Fitting these (sponsored) bath taps can add £thousands to the value….”
No… no it can’t.
So watching through as the naive developer sacks the first lot of builders… goes with more expensive ones, crashing through her budget… (wanted to spend £30k… with a little help from mommy and daddy… blew £78k on it and didn’t even touch the garden)
This scene pops up as they show the progress…
Unless there’s another socket out of shot above that chase, then vertical run isn’t in any prescribed zones.
Edit. I just noticed a cross on the wall beneath the vertical run…. Labelled “coax”
I think they forgot.
I think maybe who ever chased the socket in decided that they should leave room for the coax 🤦‍♂️
I actually have 20meters of so of H07RNF in 4 core that I bought for this reason, but the smallest I could get is 1.5mm, and it's thicker than armoured. You just can't get it into most PIRs.
It is not so common but I am sure I have seen 1mm H07RNF which would be a better match.
I have also used Flexishield 3C+E 1.5mm for that application and it works fine, but a bit more expensive.
Hob circuit lost power but all mcbs are powered up on main board, then notice the main tails are split
no way don’t say someone’s put another consumer unit behind them units to supply the hob! No access at all
had to cut a big access panel in the side of the new drawer unit and found it
kitchen was only put in a year ago 🙄
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
