View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
No. That was the electrician.
Easier to snap apart?
Never liked using them as a fixing hole, unless it’s a really thin screw.
The thread cutting into plastic could get too close to a live terminal.
Agree. It really needs to be a machine screw and nut so that there is no risk of that happening
I have come across connectors completely split open when sparks have driven big wood screws into the hole in the connector to fix it to something. if you really feel the need to anchor the connector to the box then a dob of super glue would be better imo
Can we make consumer units out of the same material as that meter?
Its virtually unscathed
Err plastic?
Perhaps we should see the dangers of metal cu's and move over to plastic.
Seemed to work last time we did it.
Old plastic (bakelite) - dangerous let's move to metal.
Old metal - dangerous let's move to plastic
Old plastic - dangerous let's move to metal
So when's the next switch over planned for?
Last time I had that scenario (DNO head burst into flames and set fire to CUs directly above it), DNO sent an invoice to the customer for replacing the head, claiming that the source of the fire was one of the CUs.
Basically the same scenario here, dno moved to an outside cabinet at no cost.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
