Darkwood
I think new cabinets might be a good idea, the site owner probably doesn't realise that they are their responsibility.
Good point, but how does one go about changing a cabinet that the DNO's cutout & meter is in?
I guess it might be possible to cut away the old box and fit a new one "around" the kit with a gaping hole in the bottom to clear stuff, but the only proper solution is going to involve the DNO replacing the cutout, and the meter supplier re-doing their bit, etc. An no power during the operation of course, which becomes an issue of they both of them can't complete both jobs on the same day.
I've changed a meter box with a cut-out in: the DNO turned up, disconnected the supply cable (taped a boot over the end and left if flapping about), then sat and watched while I changed the box, then reconnected the cable in the new box. They waited till I arrived to start disconnecting. I did feel a bit self-conscious being watched, but I think they (2 guys, in separate vans) were not in any hurry!
Darkwood,
vjsmarwick,
