Guest viewing is limited
Darkwood
Looks like a good idea to me. I'm in the middle of doing some decorating and I'm planning on putting a new socket in. If I just chisel out enough to glue the socket in then all I need to do is run a 45 deg channel to the new socket. The current one is already a spur so I'll just use 1mm cable (got a reel of black in the van) so that I don't overload it and job done. Saves on the cost of a back box and less work.
you could be on to something ...
congratulations. you has just passed all the criteria to become a masterbatorbuilder.
...and twist those CPCs together so that you can get them into the same piece of sleeving...
8K
Darkwood,
vjsmarwick,
