Guest viewing is limited
Darkwood
Not typical but a good or should I say bad example of things I find in people's houses. Although typically the worst is saved for rented properties don't you find?
This is what looks to be a hinge screw in the neutral block.
at least the cpc's are connected. seen loads cut off. down to the "cpc is to strip T/E, no other purpose" brigade
No.....It's to stop the electricity leaking out.
it doesn't leak tese days. that's why tesla invented a.c. as edison's d.c leaked out. with a.c. all the electrons thatr try and leak out are then pulled back by the 180 negative cycle. and it's a never ending thing 50 times a second.
8K
Darkwood,
vjsmarwick,
