Dodgy trade pictures for your amusement! - 1 Million Views! | Page 480 | on ElectriciansForums
Darkwood
Still not as high a capacity as the 6mm bolt in the plug on a farm I found recently!
Now that is silly and dangerous. All that was required was a sufficiently high rating to cope with the spiky 25A odd maximum welding current and the Lord knows what inrush that temporarily extinguished every fluorescent lamp on the place.
I totally agree highly dangerous, it was on a home made extension lead with a 32a socket on the end for 'Welding round the farm' it had packed up with a large pop apparently and took out the sockets mcb.
I told them it had its last welder plugged in and was only good for the scrap bin!
Worked in the (13A) plug on my 180A oil filled arc welder for 30 years without any problems.
Is there a farm that didn't have one of those (Pickhill Bantam is one name I remember) ?
At one of the farms I worked at in my youth, they had need to run one some distance from a socket - so extension lead, and obligatory 1/4" bolts to replace the annoying fuses that would otherwise blow. I wasn't there to see it happen, but I saw it afterwards ...
Fairly decent quality 13A rubber trailing socket and plug - both opened up like a peeled back banana with blobs of brass on the ends of the wires. Of course, this was long before we all carried mobile phones with cameras on them.
Pickhill Bantam was the blue one, and the other was Oxford, in a tasteful shade of light green metallic.
Mine's now in semi retirement, having been replaced for most things by a Mig, but still comes out occasionally when there's heavy stuff to be welded. Fitted with a blue 32A plug now though, and doesn't trip out a 30mA RCD.
Ah yes, the Oxford.
Weren't some of these oil filled units "a bit dodgy" in that if you mishandled them (no, that would never happen on a farm !) the windings could distort and make the casing(?) or secondary live ?
Ah yes, the Oxford.
Can't remember the details, but mine shorted live to case once. Several bolts around the top to undo, then I lifted the innards out of the oil with an engine crane. Whatever was wrong was obvious, easily sorted and hasn't happened again.
