Doepke Busbar | on ElectriciansForums
Discuss Doepke Busbar in the The Welcome Forum area at ElectriciansForums.net
Electron
Altrincham, Cheshire
I was unable to add a new MCB (tried CED and MK) to a Doepke consumer unit because their busbar seems to be a unique shape. photo attached. Has anyone else encountered this problem? If so, what solution worked.
After considering that correct above post.If someone were to trim the plastic from the sides of the terminal fixing screw a lot of mcbs could be made to clamp that busbar
most MCBs come with the facility to fit that busbar. some you need to snip out a bitofplastic. or change the busbar to a standard "comb" type.
Reply to Doepke Busbar in the The Welcome Forum area at ElectriciansForums.net
Yes that does appear to be the case. I may get an electrician to fit the correct glands. Thank you.
The legs on the bus bar are too long for the new rcbos
