I was unable to add a new MCB (tried CED and MK) to a Doepke consumer unit because their busbar seems to be a unique shape. photo attached. Has anyone else encountered this problem? If so, what solution worked.
I wouldn't usually consider using an MCB which differs from the board but I can't buy a new Doepke MCB. Only second hand ones are available.Did any body tell you that you can not mix any other mcb to a board other then the correct manufacturers mcb .
