So the story is i want to train in France and i'm due to start the training next Monday, although due to a change in circumstances we will be moving back to the UK after my current house sells.
I'm now wondering whether there's any point spending several months and several hundred hours working for free in various companies to get this qualificqtion if it's not going to be acceptable in the UK ?
I'm not sure what i'd have to do to convert the qualification over.
Anyone got any insight?
Thanks a bunch guys.
My Rural Farm House is in the Dordogne and I am speaking of fifteen years of experience, the water main in our area is at 6bar and is turned down to 3bar through the pressure release valve as recommended by all the Ballon manufacturers I have investigated, can't say I have ever been in 200 other house's in the whole of my life (over 70) and in any case have never asked what their water pressure is, if indeed you have been in that many houses and assessed their water pressure I suspect you are a plumber and that would explain everything. :yum:
That would explain actually knowing about France and what goes on here ? Like how people don't, at all, mostly have back boiler central heating systems ?
Maybe they do in 'the' Dordogne, which, as you've decided to call it 'the' shows me you don't really even speak French properly and probably get all your information off other expats from online groups where nobody has the first clue what is going on.
Just an FYI, French people call places 'the' something. People who badly translate into English also do this even though we don't refer to places like this in English. It's 'Dordogne'. The same way it's not 'the Mayenne' or 'the Lot'.
Good day to you, know it all but know nothing expat.
In my experience working in the building trade here the tradesmen are very picky about the way they do things and a proper electrician is putting out quality, safe work. I've seen a lot more rubbish work in the UK, but one of the problems here is there are so many old systems that have been fudged. My house was declared as unsafe and my supply was cut by ENEDIS soon after i moved in, for safety reasons, and yet there had been a 93 year old woman living here before us.
The quality on site is probably due to a 35 hour work week not including the massive lunch breaks they take and the fact that they are paid like crap! Cards in sparks jobs here are basically only a little bit above minimum wage, whereas self employed guys are charging anywhere from 200-700 a day. Cards in jobs are averaging around 1700euro before tax - minimum wage (called SMIC) is 1500 a month.
One spark wanted 900 euro to fix a consumer unit to the wall in my mates house, no wiring done. OK, the big 4 rail Le Grand units are like 600 euro but he wanted 900 in total just to literally put 4 screws on the wall and put the tails in, half hours work.
I just know from doing my own plumbing in my own house that the fittings are atrocious. Every single part of them. The most expensive toilet cistern mechanism you can buy is garbage quality. The fittings are crap, whether from a brico or a professional plumbing place (i've used both), the compression fittings almost always leak without ptfe when the entire point of a compression fitting is you shouldn't need ptfe. Horrible all round. The plastic stuff is crap too.
A professional plumbing centre told me you were only allowed to solder gas joints and not water joints due to the pressure. He said you used to be able to but the rules had changed (this was in 2017.) Not sure how true or whether he was just trying to sell me his hideously expensive braizing stuff. I just ended up using push fit brass fittings since the compression fittings are terrible.
4 bar is standard in farm houses - i've got one and i've been in several others and it's always set to 4 bar. Not a problem when you have a regulator attached to the incoming mains as you can simply turn it down which i've done here.
Not sure about most rural properties having a brouilleur with the burner, i've seen one in the more than 200 farm houses i've been in. Most people have a burner with no boiler or electric rads.
That said, you definitely can have a header tank set up. It's things like electric showers that aren't allowed and lots of expats try to bring them with them. I nearly did until i realised my pressure + a water heater does the job better than any shower i've ever had.
I see one part about where some plumbing store for professionals told me one thing, which i admitted could be false, and the rest is all personal opinion mixed with factual information.
All opinion.
Fact.
More facts.
More facts... - you're not allowed anything electric in zone 1 (ie the shower).
So not sure what you're referencing to be honest.
CamoElectric not quite sure why you quote yourself then comment on what you originally said, makes it quite confusing when you diss your own comments
Essex
United Kingdom
Trainee Electrician
Does anyone know if French qualifications are accepted in the UK ?
Electrics,
UNG,
