Neilandrew
Discuss Does anyone know where this red wire goes..it came out and I have no idea where to put it...it's a rose on my landing ??? in the UK Electrical Forum area at ElectriciansForums.net
No..it's in the cable that connects to the blueIs the lose red in the same cable as the black which connects to the brown.
Yeah..there's two lights on the landing and it isn't working nowWas there previously another light nearby that is no longer in use or now doesn't work? If so, was it controlled by the same switch as this one, or another switch?
That would make sense as the black also came out...must have been a loose screw...thanks for all your help people....In which case it is likely that the floating red is a switched line to the other light. If so, it came from the same terminal as the black that connects to the brown core of this light's flex. That black should have had a red sleeve to indicate it's a switched line. Needs re-doing properly though...
(Also in that case, there's no particular reason to suspect a borrowed neutral.)
a daffodil ??What are you going to replace the rose with?
Reply to Does anyone know where this red wire goes..it came out and I have no idea where to put it...it's a rose on my landing ??? in the UK Electrical Forum area at ElectriciansForums.net
