Does anyone still use connector block..?
Dustydazzler
I still have loads of 5a & 15a screw connector block strips , I use the odd bit occasionally
just wondered if anyone else still buys & uses connector block or is it all Wagos now ?
Always have some in my toolbox.
Mostly used for temporary connections and links etc for testing and fault finding.
Rare to use it for a permanent joint, I prefer wago type connections for that
I have some as well, the fancy ones with the tab under the screw to avoid trashing the cable, but would generally recommend Wagos.
The screw terminals I do still use are the DIN rail sort, though you can get sprung clamp ones for that as well.
They have their places, but don't use them if I can Wago instead. Sometimes, as a temporary repair, they are ideal...I used one to connect a broken throttle cable on a Simca 1100 in 1974...perfect!
I always use wagos or if it's for a permanent joint, push fit crimps- handy for when cables are cut too short or break behind a socket outlet or fcu and you can't get to it with rachet crimps!
SIMCA??? SURPRISED THE EXTRA WEIGHT DIDN'T CAUSE THE ENGINE TO DROP OUT.
Dustydazzler,
pc1966,
