Does House built in 1960 Need Rewire? | Page 2 | on ElectriciansForums
Discuss Does House built in 1960 Need Rewire? in the UK Electrical Forum area at ElectriciansForums.net
North Wales
Hi All,
We are about to buy a 1960 built 3-bed semi-detached. The upstairs bathroom was completely renovated in 2016 with new electrical installation (including isolation box just outside of bathroom) and a small Schnieder Easy 9 consumer unit placed by existing fusebox understairs (see picture).
[ElectriciansForums.net] Does House built in 1960 Need Rewire?
We had an electrician around who stated the wires in downstairs utility are about 10 years old (visual inspection). He also visually checked the sockets in kitchen and said that, except for the absence of earth wire, the condition of wires looks OK.
However, the electrician did not offer to do a PIR, and instead looked at fusebox understairs and said I need rewire! He has quoted about £3300 +Vat to do the rewire.
Do the wires by fusebox look sufficiently OK?
Can we get a full consumer unit, change sockets and light and complete any work highlighted by a PIR?
We really want to avoid an unnecessaryrewire. We expect to live here for 10 years or more.
Thanks.
Even Parliament is getting a rewire!
OP, depends on where you want to spend your money. I'm currently working at a property, that's having a new kitchen & utility fitted for several thousands of pounds. A new gas boiler has been installed, and they spent nearly £800 on vertical radiators alone. They also had a new bathroom installed a few years ago. You get my drift.
So I'm altering the wiring for the kitchen & utility, which fortunately was part of a relatively new extension, with recent new wiring.
However, parts of the remainder of the house has wiring circa 1960, some of the lighting circuits have no earthing. I suggested to the owner to have a proper inspection & perhaps consider a rewire, work too much for me to do, so no conflict there IMO.
Reply, was well something we can't afford it, we'll get it done when we have too. I don't understand people spending thousands on renovating their homes, but don't want to get the basics right.
Cable manufacturers appear to guarantee the expected lifetime of their cables between 20-5o years BASEC - British Approvals Service for Cables - http://www.basec.org.uk/News/Basec-News/Life-Expectancy-of-Cables
So perhaps put off that new kitchen & consider a rewire.
but they can't show off buried cables to the neighbours, can they?
And that's the crux of it most times!
If they get the heating upgraded they can show off their new all singing and all dancing boiler with 10 years warranty and energy efficiency of 95% which they have just paid a small fortune for. But re-wire, where's the fun in that? a few new socket & switch fronts and a new "fuse board" under the stairs... boring!
Hi All,
Thanks for the replies - all very useful.
I am in my parents 1940's built house which had a rewire in 2003 (unfortunately, electrician did not give a certificate, but I watched the whole house being rewired).
The electrics still have an old wooden board with meter and some other things attached (see pics). What are these for?
Hi All,
Like IP at the top of the CU
Hi All,
on the left of the board is the meter, on the right is the service cutout which contains the supply company's fuse, you also have a red link which appears to feed through the wall, presumably providing the electricity supply to your neighbours?
I don't see a Tns connection or a Pme so possible TT
The consumer unit appears to have enclosed cartridge fuses
It seems to be a split load consumer unit with Rcd covering half the board
If I am correct,you may need work very soon,the non Rcd circuits may not be adequately protected
The TNS connection is via the braid connected to the Henley block just to the left of the cutout, the braid will either be clamped to the lead with a proprietary clamp or by a plumbed joint.
Reply to Does House built in 1960 Need Rewire? in the UK Electrical Forum area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
What is the distance from the point outside the house to the shed?
