Does this comply with 314? | Page 7 | on ElectriciansForums
Discuss Does this comply with 314? in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Been at a place today.......... brand new loft conversion.......... so an additional CU has been fitted for the lights and sockets ......................
Thinking specifically about 314.2 :
[ElectriciansForums.net] Does this comply with 314?
I would say that it doesn't............
Opinions please
and more to the point, this conversion probably cost about ÂŁ45k so using RCBO's wouldn't have been noticed................
The last one I saw was where a new single RCD board had been used for the entire house and loft conversion.............. why do people do this?
Db for the loft sockets and lights on one rcd.
Your worried about loss of power to the whole loft.
I'd say that it's fine.
The rest of the house wouldn't be affected I wouldn't be worried about it.
I see the point in individual rcbo protection but individual rcd protection for all circuits isn't a requirement tho certainly not prohibited.
Upto the individual installer I'd say.
So why don't we fit single up front rcd boards any more then?
Still go back to the original design for this install. Single RCD for both lighting & power for a loft conversion. Would 'you' put those circuits on the same RCD in the CU, if there was space?
Why does the loft need to be on its own circuit as in lights in particular?
Doesn't, so if it was on different RCD to the sockets, that would be just dandy.
Thing is 314.1 (i) is non descript, everyone is opinion by definition is correct. Personally, I wouldn't put these two circuits on the same RCD, likewise I wouldn't put all kitchen circuits on the same RCD. Circuits in a typical domestic garage, could. All down to your interpretation of that reg.
I'm now off to cook me leg of lamb on the bbq rottiserie. Thought I'd share that, 'case you wondered where I was :D
Reply to Does this comply with 314? in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
