Does this comply with 314? | Page 8 | on ElectriciansForums
Discuss Does this comply with 314? in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Been at a place today.......... brand new loft conversion.......... so an additional CU has been fitted for the lights and sockets ......................
Thinking specifically about 314.2 :
[ElectriciansForums.net] Does this comply with 314?
I would say that it doesn't............
Opinions please
and more to the point, this conversion probably cost about ÂŁ45k so using RCBO's wouldn't have been noticed................
The last one I saw was where a new single RCD board had been used for the entire house and loft conversion.............. why do people do this?
As it's an eicr the most you can recommend is an improvement if there's a safety issue,however it's not an unsatisfactory outcome in its own right is it?
Hum ........... not a "safety" issue in its own right but its an elderly lady ..... and as it happens I've commented on my report that the board / installation would benefit if it we to be arranged differently .....
What is the difference in price between a 5+5 consumer unit and one with RCBO's if for eg. 7 ways were used ?.It is down to being competitive whilst RCBO's is the best design it is accepted that a split RCD consumer unit complies if not we would all be pulled up by our respective schemes. If you are pricing up a job that only specs say Hager the price difference will still add up to a bit of a difference over a few houses.
It maybe would of been a good idea to install a light at the top of the stairs from the lighting circuit below. Not knowing the floor layout it is hard to say.
Reply to Does this comply with 314? in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
