Does this conform to regs? | Page 2 | on ElectriciansForums
Discuss Does this conform to regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It depends on what the manufacturers rated them at. I've got a pair here on my desk rated at 7 sheets with a bit of a buckle twist thing going on.
also, a small child could pull those scissors out and decide to run down the corridor while holding them, which as we should all know is almost certainly lethal to any child not accompanied by a grown up.
I've called Blue Peter to let them know about this flagrant breach of their guidelines on the subject.
Reply to Does this conform to regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
