Hiya,
Our neighbour runs an unarmoured cable on our land where I park my car, buried about an inch under the soil. This is used to power their garage and EV charger.
They have said that they have attempted to comply with BS7671 as it is in a green plastic pipe that looks like a hosepipe. We are still concerned about the safety, particularly as I drive my car over it and it it outside our back gate, so also accessible to the public. I'm not an electrician so getting a bit confused, but everything I'm reading about BS7671 leads me to believe that this should be an SWA cable and buried deeper underground. Can anyone give me advice please?
I wonder what would happen if you had a bonfire close to or over the cable?
Can you ask them where they get this green plastic hose pipe I've got a swa to run in for a shed but that looks like it might be a cheaper option .sorry im just funning with you if it wasn't electricity and we were talking about something else I'd put a spade through it .don't do that though lolHiya,
Why not put a spade through itCan you ask them where they get this green plastic hose pipe I've got a swa to run in for a shed but that looks like it might be a cheaper option .sorry im just funning with you if it wasn't electricity and we were talking about something else I'd put a spade through it .don't do that though lol
That actually happened on a job .they were digging up the drive with a mini diger and pulled a swa cable for outside lights and sockets .it almost ripped the consumer unit off the wallNot that I would condone damaging this illegal cable, but it may get caught on a rope tied on the back of your car and pulled out of the ground and the charge point and the consumer unit, now that would be inconvenient.
Is there wellies to go with that as well
I have seen the same digger driver pull up an SWA supply to a tower crane that he installed the day before.That actually happened on a job .they were digging up the drive with a mini diger and pulled a swa cable for outside lights and sockets .it almost ripped the consumer unit off the wall
Ouch bad day at the races.I have seen the same digger driver pull up an SWA supply to a tower crane that he installed the day before.
It certainly doesn't sound their attempt was anywhere good enough, certainly doesn't comply with BS7671 nor likely to get a Part P Compliance certificate issued, nor perhaps ENA/DNO approval #16 (not for the installation but unlikely to have been applied for!).they have attempted to comply with BS7671
Why would you need welliesIs there wellies to go with that as well
Where would you be without your welliesWhy would you need wellies
