Does this require Main Bonding? | Page 3 | on ElectriciansForums
Discuss Does this require Main Bonding? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
The water pipes enter the house in metal, then there are a few cm's of copper after the stop cock and then plastic. It is hidden behind the kitchen draws (which can be removed to access).
Does this require Main Bonding? The stop cock tests as 0.36Ω to earth, it is TNCS.
I just cant see how fitting a Main Bonding cable achieves anything in this case?
Reply to Does this require Main Bonding? in the UK Electrical Forum area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
