Does this wiring look ok? | Page 3 | on ElectriciansForums
Discuss Does this wiring look ok? in the UK Electrical Forum area at ElectriciansForums.net
Norwich
I just had some work adding sockets and some fused switches. But I'm concerned that the wiring at up to scratch.
[ElectriciansForums.net] Does this wiring look ok?
it'll be OK. plasterer will nick them with his trowel, wet-pants will run his pipes in front of the sockets, and kevin will screw through them. then when "sparks" does his bang test, all will be revealed.
The sockets have been moved down which left the 2 top ones empty. As requested via the spec sheet for the kitchen refit from my housing association.
so it seems that the cables are too short and that's why he's bodged all those connections. to say that's dog rough is an insult to our canine friends. a 4 legged pressure group is on his scent.
Words fail me .... no ..... wait a second .... I've found some .....
abominable, abysmal, alarming, appalling, atrocious, awful, bad, contemptible, diabolical, dire, disgraceful, disreputable, dreadful, frightening, ghastly, gruesome, hideous, horrendous, loathsome, reprehensible, shameful, and, of course ..... incompetent.
Reply to Does this wiring look ok? in the UK Electrical Forum area at ElectriciansForums.net
Brilliant. Thanks Brian much appreciate the advice.
Depends how it is connected, which is of course a practical issue, the terminals are usually designed for 6/10mm cable so if you can ensure the...
