Doing my first sub-main in SWA. | Page 2 | on ElectriciansForums
Discuss Doing my first sub-main in SWA. in the Talk Electrician area at ElectriciansForums.net
Mechanical protection not needed on any thing over 4mm.
I refer of course to the MEC
I guess 16 will do, it's a smallish flat. I wasn't sure about being able to use the armouring for the main earth. Are you saying it's not enough? The calcs for it are mind boggling. (543.1.3 17th ed) How the hell do you work out the CSA of the armouring?
And is I in the equation the same as max PFC?
I only use the armour as a way of beefing up the earth and mech protection.
If your not running three core 16mm yoy should run a seperate 16mm MET
Sorry to bang on about it but where does it say about running a separate earth and why isn't the armouring sufficient.
There is no requirement if you are using 3 core SWA, but obviously you need one if using 2 core plus seperate earth.
However, if there is no need for mechanical protection and it is going to be run in trunking, then i would suggest you ask your supplier for 16mm split concentric cable.
Doddle to run and terminate with standard plastic compression glands.
Have a look here:
Electrical Cable - Split Concentric Cable BS7870
Have a look here:
wow! never seen that before! whats with all the neutrals???
they were terminated into consumer units from sw/fuse isolators down in the mains room. both ends were heat shrinked, neatrals were carefully bared off and twisted together, and heat shrinked. looks professional, rather than seeing a load of seperate neautrals etc.
Reply to Doing my first sub-main in SWA. in the Talk Electrician area at ElectriciansForums.net
totally agree
Sounds more positive.
