Domestic Departure from BS7671 - Advice | on ElectriciansForums
Discuss Domestic Departure from BS7671 - Advice in the Domestic Electrician Forum area at ElectriciansForums.net
SparkyChick
Supporter
South Wales
Hi all,
As the title suggests, I'm looking for a little bit of guidance.
Long story short... kitchen remodel, was asked to install a heavy duty supply for an induction hob on short timescales as ceiling was going to be closed.
Only sizeable cable I had to hand was 10mm.
Now, in a happy turn of events, it turns out that the induction hob isn't that hungry and only needs to plug in, but the oven and microwave also require supplies. None of them are over 16A.
So my original plan was to install a BG shower CU, switch out the breakers for 16A (one for each appliance) and supply this using the 10mm on a 50A breaker from the main DB. The new CU was to be mounted on the wall, making an obvious accessory safety zone.
However, due to the construction of the kitchen units, I felt it better to have the CU inside a cupboard rather than cut a portion of the backboard away.
Where I'm seeking guidance is that this now means the 10mm is concealed in the wall, from ceiling to just below the top of the cupboard. Along the rest of it's run, it is installed in a manner (i.e. it's not at risk of damage and it's not concealed in a wall) that means it's fine to be connected to the non-RCD side of the board (the new CU has RCD protection in it).
So I have a length of cable about 10-12" buried in the wall. Due to it's location I don't believe it is at risk of being damaged by screws as it is unlikely anyone will want to hang anything there because it's effectively behind the cupboard.
I have placed a warning sticker on the top of the cupboard (Danger Concealed Cable - This includes an arrow aligned with the vertical drop of the cable). I'm going to record full details on the certificate of the location of the cable and my reasoning as to why this is acceptable.
Acceptable or not? Is this kind of departure allowed in domestic and if so is it sufficient to include your reasoning in the certificate or is there a template risk assessment I would need to use?
Your comments and thoughts are most welcome :)
My opinion with such occasions is that common sense has to apply, and I would say there is nothing wrong ..... But why not put the circuit on a rcbo?
Old Memera board and no spare ways from what I can see, so the old 32A cooker circuit is being decomissioned and replaced with a 50A feed to the sub-board.
Edit:-
Just to be clear, the current board has one RCD and the cooker circuit isn't on it.
It's maximum rated power is 3kW, and it comes fitted with a 13A plug. It's not being connected to the ring final that supplies the kitchen.
It's on it's own 16A radial circuit (2.5/1.5mm T+E - New sub-board -> 20A DP Switch -> 13A socket outlet behind units/in kickspace).
now how is going to ask for a test certs when drilling
a wall there then.
Does the cable run have to be plastered over or can it be left exposed or have suitable mechanical protection such as a metal plate?
With Departures, you as the designer have to attest that the departure offers the same degree of safety as would be provided by compliance with the Regulations.
I think that's what my concern is. As it is I can't say it's as safe because it's not, which leads on to Strima's post which I was going to reply to you with.
Time to break out the metal capping and pop a couple of layers of that over it (fingers crossed the customer hasn't filled the channel yet)!
a wall there then.
They don't need to see a test certificate... there is a warning notice on the top of the cupboard that clearly states there is a concealed cable and identifies it's location.
To answer your specific question Strima... no it cannot be exposed. Client's wife is a bit OCD about cables and holes in walls.
Part of the reason the unit was moved into the cupboard was because it was there with three lengths of T+E hanging out of it ready for the terminations and it freaked her out a little, so all the cabling has to be hidden once the kitchen is finished.
Lovely couple, just a little crazy :)
Reply to Domestic Departure from BS7671 - Advice in the Domestic Electrician Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
