SensesFailYou
Hi Guys a few questions
When you cant verify the Characteristics of primary supply overcurrent device is it a case of just putting LIM for all options?
Secondly when filling out the circuit details do you put the RCD and Main Switch as they are on the board? I usually just put the circuits in number only omitting the RCD etc but iv noticed some do? Which is best because if you do put the RCD in etc on a chint 12 way board you are looking at:
RCD
RCD
Circuit 1
Circuit 2
Circuit 3
Circuit 4
Circuit 5
Circuit 6
RCD
RCD
Circuit 7
Circuit 8
Circuit 9
Circuit 10
Circuit 11
Circuit 12
Main Switch
Main Switch
Many thanks
RCD
RCD
Circuit 1
Circuit 2
Circuit 3
Circuit 4
Circuit 5
Circuit 6
RCD
RCD
Circuit 7
Circuit 8
Circuit 9
Circuit 10
Circuit 11
Circuit 12
Main Switch
Main Switch
Many thanks
