Who are the "powers that be" and any references for this information?
Only thing I've heard in relation to DI is that the NICEIC (not sure about the other CPS') are changing their entry requirements for the domestic installers scheme so from Sept this year an NVQ level 3 or equivalent is required, effectively making it impossible for a person that has done only a DI course to join.
What’s a domestic installers course ? Is it one of those 5 day fast track oven baked things
imo 5 days isn’t long enough to become a qualified electrician. It should be 6 days
make it 7. can't have traineees lying in bed late on a Sunday. how can they face the real world then?
I heard from someone who had a NICEIC inspector around .The inspector said they are planning on not accepting DI qualification only and REMOVING those who only have the DI qualification from their scheme ?????
They won't accept the DI course as it's not an NVQ or equivalent. Those on the scheme already will not be removed, the changes only affect people joining the scheme after 1st sept 21.
It is a bit of a half hearted attempt to fix a problem that they created IMO, those already in the scheme should be given a period of time to update or even demonstrate they are bringing their qualifications up to the required minimum standard for membership, I don't think a keep on paying your fees and you will be ok to carry on is good enough you could end up with a part of the scheme membership that is below the required new entry level for potentially 30 - 40 years
The DI 'short course electrician' was nothing short of a band wagon scam to fill the coffers of the scams.
It turned Dave the plumber into Dave the Electrician literally overnight with little to no actual on-site experience.
If we really want a better standard for domesticated electrician then the scams should put on some proper courses for Dave
LukeD
Supporter
"Domestic installer " due to be binned?
Domestic Electrician Forum
Thread Tags
LukeD,
nicebutdim,
