Domestic Shed Installation | on ElectriciansForums
Discuss Domestic Shed Installation in the Domestic Electrician Forum area at ElectriciansForums.net
LGRSol
Cheshire
Hi All,
Having recently qualified as an electrician, I am beginning to understand the adhocs and curveballs that customers can throw at you.
Last week I went to quote for a shed installation. The shed is approximately 25m from the property and would be a relatively straight forward notifiable job i.e. SWA buried to a safe depth (500mm), 2 way DB in shed for 1 way lighting and ring final sockets.
Now in my limited experience, as far as I am concerned the install would be directly to the main DB and either protected by a 30mA RCD or alternativly using an RCBO. However the customer has said that they really want the source to be from a fused spur out of the ring final circuit in the garage.
Obviously I am fully aware of the regs and in particular 5.7 of Part P. As far as I am concerned, this is an absolute no go, however I am struggling to find if this is stated anywhere in the wiring regs. Before I say this to the customer please could I have some advice / thoughts.
Much appreciated,
Lee
the customer can have the shed supply from the ring if he wants.however, he will be limited to the 13A FCU as to load. far better to take feed from DB, fused appropriately. SWA will not require RCD protection ( unless TT).
As Tel has already pointed out, if the customer wants it from the FCU then he is limited to what he can use in his shed.
Ask them what they intend to plug in... They might want a heater and other stuff..
Does the house CU have RCD protection?
Hi Spoon.
The DB is RCD protected. I'll speak to the customer on monday and find out their intended usage and advise accordingly.
If they do go with the 13A FCU option, do you have any advice on the best way to do the testing the installation. It will be the first time that i've fitted a second DB. I'm assuming testing should be at the original DB (specific breaker)?
Many Thanks
Personally I'd take it from the C/U into a 2 way board, however I would put an rcd local to that board not the board in the house. Problem being that if the end trips in the house it's a nuisance to reset. The SWA will not need rcd protection.
Secondly, why fit a RFC? Just for a 4mm radial
Don't know why anyone would choose to install a ring over a radial.
Reply to Domestic Shed Installation in the Domestic Electrician Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
