Discuss Don’t like chasing in. in the UK Electrical Forum area at ElectriciansForums.net
I Could of had a cable chopped into the wall and plastered over in the time he’s faffed on with that stuff!
Yes...unfortunately the guy was recently arrested along with his mate for robbing empty houses whilst the home owners were away!You've changed man.
Anything to get rid of double yellows!they could replace all them nasty double yellow lines with copper strips. tap off the supply to properties with an earth rod banged in by the kerb. trolley buses could then be re-introduced with swingin pick-up arms to run along the strips, instead of those unsightly overhead cables.
If that's approved in Romania then it may be allowable here too courtesy of EU (?) . Yikes !!!Unbelievable
Yes, and if it over heats you will have scorch marks on the wall paper!what a bad idea, ive seen wet plaster walls that have become live due to leaking into a live socket, not 230v but still enough to give you a tingle
..Now you know where its safe to hang picture to cover scorches !Yes, and if it over heats you will have scorch marks on the wall paper!
i heard somewhere that a product will only be recalled if enough complaints are raised against it, like with those "hover" boards that were always catching fire when chargingYes, and if it over heats you will have scorch marks on the wall paper!
Reply to Don’t like chasing in. in the UK Electrical Forum area at ElectriciansForums.net
