P
Phillcbr400
I know these are pretty straight forward but not having fitted one before I thought I would ask first.
Looking on TLC I think ill go for bandera door time and the TC TRV transformer. Transformer will be about 10mtrs from the chimer. And using alarm cable doubled up.
This chimer has a separate sound for the back door, I was thinking of using this with a simple magnetic door contact for an entry chime. Question is, would this work.
Just got too find a nice button now :)
If you have any preferences with using certain makes or models what are they? Only want a wired system.
Phill
Is there a magnetic contactor/ or other device I could use for this application? It's in a domestic property so needs to look discreet.
I've been having a look around the net and not seen much.
Only done basic electronics if I'm honest so you might just lose me there tazz. Always willing to learn tho.
Thinking a relay and transformer in a nice enclosure next to the consumer unit might be a good option. I can run a switch on the back door aswell.
You're an absolute star for doing that tazz, appreciate it a lot. Very kind of you.
Lucky I can pick must of the gear up through work so shouldn't cost me much.
Say I was wanting too add another 2 door contacts onto this, how would I then go about doing this? As the only problem I can see with making up another switch or even running multiple contacts on this one, is if one contact is already open and there is already a supply to the chime/bell then another one wouldn't make a difference.
doorbell setups (wired)
Phillcbr400,
Phillcbr400,
