Double immersion | on ElectriciansForums
Discuss Double immersion in the UK Electrical Forum area at ElectriciansForums.net
P
PRETEND SPARKS
Hi guys wonder if anyone come across this one, got called to a cylinder with two 3kw elements in it, both fed from a 32a
breaker to two fused spurs with 13a protection. The shop owner says that one of the spurs banged and after this
neither element now works. Firstly thought that the supply was adequate and secondly can't understand both now not working??? Any ideas anyone. The cylinder is made by joule.
Maybe it's one of those old economy tariff set-up's
It is secondary but still got power on it also got power at element, also element bells out ok?? Confused . Com but thanx
Not sure what belling out involves but if there's 230v across the element terminals then use a clamp meter to check the current draw. If there's no current or considerably less current than the kilowatt rating of the element would suggest there should be then remove the element and replace it.
Was just checking with voltage tester that I was not down to earth with buzzer on tester etc, I was on one but not on the other?? It's the fact the one that didn't pop isn't working now, they tell me they only ever use one at a time too
Am I being thick here? Is what you are asking about as simple a setup as two immersion elements being fed from two FCUs which are fed from the same source? Or am I missing some sublety?
(Or possibly for some ridiculous reason FCU#2 is fed by load side of FCU#1? which a) will blow FCU#1 fuse, eventually and b) means immersion#2 can't possibly have power if FCU#1 fuse has blown.)
#2 & #3.....
If you are getting 230V at both element points then the problem can only be stats or elements - test all appropriately and replace whatever is faulty...
I can't see where the confusion is.
No mate you ain't being thick prob not explaining very well but the the fcu's are both terminated correctly ie feed side etc load in load etc. n yea your right it's just a simple emersion circuit with two elements etc al have to check what readings are on element, was prob doubting myself slightly but the cable size ok n fcu's ok at 13a !!
Reply to Double immersion in the UK Electrical Forum area at ElectriciansForums.net
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
Recommended Sponsor News
Hi everyone,
