for those that are not culturally knowledgeable about these things a douch is a little shower, usually located next to a toilet, that the Mohammedans use to wash their bits as opposed to using infidel bog roll.
If a douche is classed as a shower then what would you class as the shower tray, to be 600mm away from.
This has made fitting a saniflow rather puzzling.
The way I’ve gone about it is -
1, Treat the douch as a shower and take my measurements from the toilet pan.
2, As this is a separate toilet, I.e. not in a bathroom, there is nowhere within reach of the sealed flex of the saniflow that is over 600mm away so an IP65 socket has been installed on an RCBO to power the saniflow.
I’d like to know how others would have treated the same situation.
