downlight flex | on ElectriciansForums
Discuss downlight flex in the UK Electrical Forum area at ElectriciansForums.net
Sparky_Ben
what type of flex do you guys use for downlighter wiring, obviously just from the loop in, loop out JB, down to the fitting, now i know it will have to be high temperature/ heat resistant but what would the cable code be to look for in the catalogues,
thanks
I've never seen a manufacturer request it to be wired in flex. And I don't really see the need if it's a decent fitting designed to be wired into. As your just putting a unnecessary joint in. If you had to have jbs above each light I would probably use flex. I just think its easier and better to limit jbs.
I'm just doing a kitchen where the ceiling void has underfloor heating in it as well, so it's heat flex all the way from the switch onwards.
I've seen too many examples of T+E burnt out against downlighter body for my liking. So IMHO it's T+E to Ashley 501 JB (or similar 17th ed compliant JB) then heat resistant flex to downlighter.
Reply to downlight flex in the UK Electrical Forum area at ElectriciansForums.net
Of course, showing my age now!
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
