View the thread, titled "downlight flex" which is posted in UK Electrical Forum on Electricians Forums.
Sparky_Ben
what type of flex do you guys use for downlighter wiring, obviously just from the loop in, loop out JB, down to the fitting, now i know it will have to be high temperature/ heat resistant but what would the cable code be to look for in the catalogues,
thanks
Yes i do, fed up with trying to get 2 x 1.5mm T&e cables in that tiny little joint box!
I've seen too many examples of T+E burnt out against downlighter body for my liking. So IMHO it's T+E to Ashley 501 JB (or similar 17th ed compliant JB) then heat resistant flex to downlighter.
True, but I still think it's best practice.
Whereabouts in Cornwall are you?
Take it then none of you have used the click fittings then, they are designed fro 2 2.5mm T&Es to loop in loop out. no risk of melting cables
Reply to the thread, titled "downlight flex" which is posted in UK Electrical Forum on Electricians Forums.
