Drilled through cable in wall, can I fix? (Photo) | Page 4 | on ElectriciansForums
Discuss Drilled through cable in wall, can I fix? (Photo) in the UK Electrical Forum area at ElectriciansForums.net
Sam22
Manchester
[ElectriciansForums.net] Drilled through cable in wall, can I fix? (Photo)
Drilled through cable in kitchen wall, tripped the fuse box. Switched back on and everything works apart from the cooker hood.
I've called electrician and explained, given me a quote of ÂŁ120 plus VAT. Is that reasonable?
Is this something I can fix? If so, how? I have basic electrical skills (i.e I can install a new light fitting, install a dimmer switch, change a plug, etc...!)
Reply to Drilled through cable in wall, can I fix? (Photo) in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
Better off with the click prw213 as it has twin screw termination.
