Drilled through electric conduit/cable | Page 3 | on ElectriciansForums
Discuss Drilled through electric conduit/cable in the Talk Electrician area at ElectriciansForums.net
we all know the unqualified amatuer ought to practice ,then post to give us a laugh
Well done Bane, I've just logged on and started reading this thread. Surely this work cannot be classed as a "like for like replacement" as changing accessories would be and is therefore notifiable in theory.
It is a job for someone who can competantly test the circuit after replacing the damaged cable, not for DIY.
I would also wonder about the advice given "over the telephone" by the electrician concerned. If the property had a "standard" cu, not split load, then there would be no rcd protection and the possibility of a substancial earth fault being present.
Open to comments please.
Tony, whilst i agree that this guy should probably not be doing it (I was actually more interested in discussing what is 'accessible and the new maintenance free JB's:eek:), surely this would come under
A. Emergency repair (which he doesnt have to pre-notify at least)
and probably
B. Changing the cable for a single circuit only where the same size cable and route is used (which is non-notifiable)
But yes, it should still be tested and a should preferably be carried out by a sparks (thats me out of the running then!:eek::p)
Hi ShaKey,
Hope I did not appear to be having a go at anyone.
Being Accessible is another one of those open to interpretation regulations which seem to beexcessive in our industry.
I thank you for the non notifiable definitions, just a daft thought springs to mind: if you replaced every cable one at a time and using the same cable routes does this mean that you could rewire your house without it being notifiable? ;)
In many ways I think the thing that gave me the most concern was the "advice" given over the phone by the electrician.
As for you not being able to carry out the testing - well you only need to be competant!!!:D
Cheers
Tony
Thanks for the replies all, im certainly no electrician so wouldnt be able to test anything afterwards, in fact, I am the Homer Simpson of DIY.
Ive got a sparky coming today, so hopefully get this sorted, or at elast get a ballpark cost and details of what they'll need to do.
Ill keep you updated on progress.
Hi ShaKey,
Cheers
Tony
ha ha Tony, no of course you werent having a go:)
You would not believe how many students i have taught with the 'replace a single cable' rule that say, "so i could do lots of them and rewire the house"
and thats why the Approved Document says "for a single circuit only"
although it doesnt give a time scale between changing this cable, and then that cable.............:p:rolleyes:
ok this might not be the correct thing to say but to avoid to much destruction, if its a ring, disconnecting and removing the offending leg (from BOTH sockets), cut it back, tape up and poke out of the way, (label it) and then split the ring and create 2 radials?
Reply to Drilled through electric conduit/cable in the Talk Electrician area at ElectriciansForums.net
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
