Dual range cooker | Page 2 | on ElectriciansForums
Discuss Dual range cooker in the UK Electrical Forum area at ElectriciansForums.net
Hi all
After a little help please, as just completed my NVQ and AM2 and not completely confident in everything as I have only done one domestic job in my 4 year apprenticeship.
My neighbour has purchased a dual range cooker (7.4kW) and has asked if I can fit. After having a look I found this and was wondering if I am correct in what I have said:
They have had an extension and have a sub board with a 40A Rcd main switch feeding 32a mcb-skts and 6a-lights. The mains cable feeding this is 6mm SWA 3core. Obviously the range cooker would need its separate circuit so the board would need to be changed as its only a 4way but the mains cable feed would also need to be changed to at least 10mm SWA?
The neighbours plan was to go straight from the board through a wall which the range will be backed onto and terminated direct. Can't find anything in regs saying you can't terminate direct rather than through a cooker switch but is it best practice to do this?
thanks
I am going from memory now as my book is in the office but I would always install local isolation for any fixed equipment. Especially for one that gives off heat so that this can be isolated immediatly in the event of a fire.
Problem there, is that a switch intended for emergency isolation would also have to satisfy all the requirements in the Regulations for emergency switches.
Most householders will not find such acceptable.
Think he means local isolation that could be switched off in the event of an emergency
Have to say, some of the posters to this thread are turning this Forum into a joke. Keep your pi**ing contests to yourself. Either answer the OP (although there was not enough info to offer a fully informed view) or don't. Most of us can come across enough grief during a normal working day without having to sign on here and find more.
Rant over!
Reply to Dual range cooker in the UK Electrical Forum area at ElectriciansForums.net
Thanks for replying
I actually did it with a 4 core 4.0mm swa last week!
