Dual range cooker | Page 4 | on ElectriciansForums
Discuss Dual range cooker in the UK Electrical Forum area at ElectriciansForums.net
Hi all
After a little help please, as just completed my NVQ and AM2 and not completely confident in everything as I have only done one domestic job in my 4 year apprenticeship.
My neighbour has purchased a dual range cooker (7.4kW) and has asked if I can fit. After having a look I found this and was wondering if I am correct in what I have said:
They have had an extension and have a sub board with a 40A Rcd main switch feeding 32a mcb-skts and 6a-lights. The mains cable feeding this is 6mm SWA 3core. Obviously the range cooker would need its separate circuit so the board would need to be changed as its only a 4way but the mains cable feed would also need to be changed to at least 10mm SWA?
The neighbours plan was to go straight from the board through a wall which the range will be backed onto and terminated direct. Can't find anything in regs saying you can't terminate direct rather than through a cooker switch but is it best practice to do this?
thanks
Care to expand on exactly what you mean by this? It reads as though you mean put a DP switch in each end of the ring?
I was thinking more along the lines of kitchen sockets being wired as lollipop rings allowing a single double pole isolation at the kitchen entrance.
It was only a tuppenceworth thought after upstairs flats recent fire.
[ElectriciansForums.net] Dual range cooker
Originally Posted by andyelectric [ElectriciansForums.net] Dual range cooker
With other heat producing equipment in the kitchen other than the cooker there is probably a good argument for a double pole isolation for kitchen ring finals(obviously both ends) as well as cooker radials.
That's exactly what it means/say's, it can't be read any other way!!
Whats that got to do with the fixed electrical installation ? It was the upstairs occupants fault !
LOL next you will want fire stations on all street corners lol
Post #32 by Eng54 is bang on in my opinion. It may indeed be very unlikely for a cooker to need isolating in an emergency, but if it does then I would prefer some housewife didn't have to find the consumer unit, empty the contents of the cupboard under the stairs to get it, and then plunge the house into darkness when she flicks all the MCBs off. Daz
(Didn't mean for the housewife bit to sound sexist, apologies if it did)
With my Mrs, the smoke alarms have gone off way before anything catches fire.
Reply to Dual range cooker in the UK Electrical Forum area at ElectriciansForums.net
Thanks for replying
I actually did it with a 4 core 4.0mm swa last week!
